Web example: Configuring a time range
As shown in Figure-1, configure a service object group on the device to allow Host 1 to communicate with Host 2 through ICMPv6 in a specific time period.
Figure-1 Network diagram
Software versions used
This configuration example was created and verified on E9900 of the F5000-AI-55-G device.
When you configure object groups, follow these restrictions and guidelines:
  1. Assign IPv6 addresses to interfaces and add the interfaces to security zones.
    # On the top navigation bar, click Network.
    # From the navigation pane, select Interface Configuration > Interfaces.
    # Click the Edit icon for GE 1/0/1.
    # In the dialog box that opens, configure the interface:
    1. Select the Trust security zone.
    2. On the IPv6 Address tab, enter the IP address and mask of the interface. In this example, enter 20:1:1::1/112.
    3. Click OK.
    # Add GE 1/0/2 to the Untrust security zone and set its IP address to 30:1:1::1/112 in the same way you configure GE 1/0/1.
  2. Create a service object group.
    # On the top navigation bar, click Objects.
    # From the navigation pane, select Object Groups > Service Object Groups.
    # Click Create.
    # In the dialog box that opens, configure the service object group:
    1. Enter a group name. In this example, enter test-fa.
    2. Click Add.
      Figure-2 Create a service object group
    3. In the dialog box that opens, configure a service object.
      • Select object Protocol name.
      • Select type ICMPv6.
    4. Click OK.
      Figure-3 Create an object
    5. On the Create Service Object Group page, click OK.
  3. Create a time range.
    # On the top navigation bar, click Object.
    # From the navigation pane, select Object Groups > Time Ranges.
    # Click Create.
    # In the dialog box that appears, enter name test-time and then click Create for Periodic time range.
    # In the dialog box that appears, configure the time range:
    • Set the start time to 08:10.
    • Set the end time to 17:10.
    • Select Monday, Tuesday, Wednesday, Thursday, and Friday.
    # Click OK.
    Figure-4 Configure a time range
    # In the Create Time Range page, click OK.
  4. Create a security policy from zone Trust to zone Untrust.
    # On the top navigation bar, click Policies.
    # From the navigation pane, select Security Policies > Security Policies.
    # Click Create.
    # In the dialog box that appears, configure a security policy:
    • Enter policy name test-time.
    • Select source zone Trust.
    • Select destination zone Untrust.
    • Select type IPv6.
    • Select action Permit.
    • Select service test-fa.
    • Select time range test-time.
    # Click OK.
# Verify that you can ping Host 2 from Host 1 successfully in the time period specified by the time range.
C:\Users\abc> ping 30:1:1::10
Pinging 30.1.1.10 with 32 bytes of data:
Reply from 30.1.1.10: bytes=32 time<1ms TTL=254
Ping statistics for 30.1.1.10:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
# Verify that you cannot ping Host 2 from Host 1 and the corresponding session does not exist at any time beyond the time period specified by the time range.
